AERO COMMANDER 500 - Cargo
Download: http://www.fs9retro.de/fs9/downloads/ac500ca1.zip
Download Paintkit:http://www.fs9retro.de/fs9/downloads/ac500Paintkit.zip
"Smugglers Dream" Repaint von Sean Doran
Download: http://www.fs9retro.de/fs9/downloads/ac500sd.zip
Checkliste von Werner Schott: http://www.fs9retro.de/fs9/downloads/FS9C500.ZIP
Unsere Frachtversion des AC500 von Milton Shupe, Scott Thomas, und Andre Folkers kam ursprünglich so in Petersburg an
Wir haben dann eimerweise Farbe besorgt und die Mühle wieder ansehnlich gestaltet
Zum Glück war die "Inneneinrichtung" noch im Top Zustand
Fakten (lt. Doku)
- Code:
MODEL 500
Price.................................................$65,750
Years Built...................................... 1958 - 1960
Serial No. Range....................................618 - 852
Total Built...............................................101
Power Plant................................Lycoming O-540-A2B
Rating.....................................250hp @ 2575 RPM
Fuel, octane - capacity (Gal).................. 91/96 - 156
Fuel Consumption GPH...................................11.9
Propeller........................................ 80" 2-blade
Weight (lb), empty - gross........................3850 - 6000
Dimensions :
Wing span (Inches) - area (Sq ft)...........588.56 - 255.00
Fuselage length - height (Inches)...........421.25 - 174.00
Volume, cabin - baggage area (Cubic feet)..........177 - 32
Seats ................................................5 - 7
Performance:
Takeoff over 50' obstacle.............................1,400
Landing over 50' obstacle.............................1,350
Service ceiling (feet)...............................22,500
Single-engine ceiling.................................8,000
Maximum range (miles).................................1,100
Cruising speed (MPH TAS)(70% @10,000 ft)................199
Takeoff - landing speed.............................87 - 82
Best rate-of-climb......................................110
FS NAVIGATOR - ParameterIf you are running FSNavigator, the below information may be inserted into the aircraft data for calculating time and fuel consumption.
(Unsere Flugpläne werden mit diesen Daten angefertigt)
[AC500 Aero Commander]
climbspeed=124
climbfuel=36
climbrate=1375
cruisespeed=160
cruisefuel=12
cruisealtitude=10000
descentspeed=160
descentfuel=10
descentrate=1375
fuelmeasure=0
revision=1
