| Thema: FREEWARE: Aero Commander 520 Mo 23 Dez 2013 - 5:55 | |
| Maximal 7 Passagiere haben in dieser Version Platz - bitte bei euren Postings berücksichtigen. 143kts Reisegeschwindigkeit - wir setzen den AC520 für zahlungskräftige Kunden für Entfernungen bis ca. 300nM ein. Da schlägt das Herz höher...das Uhrenwerk des AC 520 komfortabel Reisen - Alaska Sky Service zeigt sich hier von seiner besten Seite - Code:
MODEL 520
Type Certificate: 6A1
Date Certificated: January 31st 1952
PCLM: 5 (2 at +104, 3 at +165) Can have 6 or 7 seats with emergency exit (Drawing 5870041) and structural provision for center seats (Drawing 5870027).
Number Built: 150
Certificated by: Aero Design & Engineering Company Serial numbers 1 through 150 (150 aircraft)
Engines: Lycoming GO-435-A2 Serial number 1 (1 aircraft) Lycoming GO-435-C2 Serial numbers 2 through 20, 22, & 24 through 38 (35 aircraft) Lycoming GO-435-C2B Serial numbers 21, 23, & 39 through 150 (114 aircraft) Lycoming GO-435-C2B1 none delivered, but was used later as an up-grade Lycoming GO-435-C2B2 none delivered, but was used later as an up-grade (but not listed on T.C.D.S.)
Propellers (hub/blade): Hartzell HC-12X20-8C/9333C-3 Serial numbers 1 through 14 & 27 (15 aircraft) Hartzell HC-12X20-9C/9333C-3 Serial numbers 15, 16, 18-20, 22, 24-26, 28-38, & 80 (21 aircraft) Hartzell HC-82X20-2/9333C-3 Serial numbers 17, 21, 23, 39-69, 71-74 & 76-79 (42 aircraft) Hartzell HC-82X20-2A/9333C-3 Serial numbers 70, 75, 81-88, 90-99, 101-125, 127 & 130-150 (67 aircraft) Hartzell HC-82X20-2C/9333C-3 Serial numbers 89, 126, 128 & 129 (4 aircraft) Hartzell HC-83X20-2C/8433 Serial number 100 (1 aircraft)
Fuel: 80/87 or 91/96 minimum grade aviation gasoline Fuel consumption: 13.5 U.S. gallons per engine per hour at 2,600r.p.m. Fuel capacity: 150 U.S. gallons (568 litres) total [5 inter-connected tanks] 145 U.S. gallons (549 litres) usable
Oil capacity: 6.0 U.S. gallons (22.71 litres) total (3.0 gallons each engine) 4.5 U.S. gallons (17.03 litres) usable
Die Facts für den FSNavigator [list][AC520 Aero Commander] climbspeed=140 climbfuel=36 climbrate=1000 cruisespeed=143 cruisefuel=14 cruisealtitude=10000 descentspeed=140 descentfuel=10 descentrate=1000 fuelmeasure=0 revision=1[/list:u] DOWNLOADSAircraft http://www.fs9retro.de/fs9/downloads/ac520v31.zip ca. 10 MB Checkliste AS 520 von Werner Schott http://www.fs9retro.de/fs9/downloads/FS9C520.ZIP |
